Criss-Crossed Cross Sections
Written by Chris Goodell | December 10, 2008
Copyright © RASModel.com. 2008. All rights reserved.It happens to the best of us. Occasionally, we import GIS cross sections that we accidentally drew in backwards (i.e. right-to-left looking downstream, instead of the required left-to-right). As a result, you can get a criss-cross deal where the correctly drawn and incorrectly drawn cross sections are located (see figure). You can also tell something’s wrong when the River Station label is on the right side of the cross section (looking downstream). RAS always places that label on what it thinks is the left side of the cross section.
It’s very easy to fix. Simply left-click on the cross section you want to fix and select “Reverse XS Stationing”. Of course you could always go back to your GIS application and redraw (or reverse) each cross section, but who wants to do that?
on January 3, 2013I'm seeing a bizarre issue with some cross sections ending up reversed (mirror image of correct), but everything else appears OK (correct labeling unlike the image above, etc.). I'm generating them in Geo-RAS (for ArcMAP 10), and drawing them correctly from left to right. Any suggestions?
on January 3, 2013Hmmm. That's a good question. Are your stream centerlines and flow lines all drawn in from upstream to downstream? That might be the cause. Otherwise, I'm not sure. I'll keep thinking about it. Please post a reply here if you figure it out.
on January 3, 2013Thanks Chris. Yes, they're drawn up to down, and what's more strange is that cross sections above and below the mirrored ones turn out just fine. I laid these cutlines over a surface about a year ago using ArcMAP 9.3 and it worked OK, then I replaced the surface recently, now using ArcMAP 10, and this occurred.
on March 10, 2014I'm having a problem where a few of the cross sections I entered into Hec-Ras have reversed stationing and after using the reverse stationing tool on those few cross sections, I now have the criss-cross issue you show above.
The stationing is now correct but I still have the criss-cross issue. Do you have any suggestions on how to get rid of the criss-cross without changing the stationing? Thanks.
on March 12, 2014You may have to still reverse your Cross Section cutline coordinates. Go to the GIS Tools menu item in the geometry window and select XS Cutlines Table. If you scroll to the affected cross sections and then just "flip" the table, that may fix your problem. Good Luck.
@RASModel
Brian
on June 27, 2014Reversing the XS stations did not work for me (4.1) – it mirrored the points but didn't flip the cross section orientation around. The solution for me was to left-click and "Move Cut Line Upstream/Downstream", then choose the existing location as the 'new' location. This caused the program to flip the orientation of the cross section.
Unknown
on February 19, 2018Hey, i am having an error as all ,y cross sections are OK. just the last cross section is coming cris crossed as shown in image. I tried reversing the station as per given in the above solutions but still the error persists. Also, when i deleted that particular cross section, the C/S above it (which became last now) also is getting reversed. Kindly help me on this.
Chris Goodell
on February 19, 2018Strange. I have no idea why that’s happening. Let me know if you solve it.
on February 20, 2018Problem can be solved by correctly defining the river stream line in the vicinity of the affected cross section.
on May 14, 2018I received a HEC geometry file for a project where the x-sec look correct (left to right looking downstream) however, the x-sec's have been numbered backwards (0 being the furthest upstream) and the downstream reach length for each x-sec is actually the distance to the next upstream x-sec. Is there a way to easily reverse this?
Chris Goodell
on May 15, 2018Try multiplying the river stationing by -1, so that all of the stations have negative values.
on May 17, 2018Thanks, I tried in the stationing table to change them all at once like that, but the program wouldn't allow it, because it reverses the direction. Told me I'd have to change each station individually in the cross-section editor. So that's what I ended up doing.
Unknown
on May 22, 2018Hi , I really appreciate your effort in this blog.I have a question ,can I change flow direction in Profile Plot Output , I need the flow from left to right, can you do this ?
Unknown
Chris Goodell
on May 22, 2018Unfortunately no. You’ll have to send your results to Excel to do that.
