HEC-RAS 6.0 beta 2 is now available!
Written by Chris Goodell | February 3, 2021
  1. Ian Sharp
    on February 5, 2021
    Interestingly, the RAS release notes say “Version 6.0 of the River Analysis System (HEC-RAS) is now available. This Version supersedes Version 5.0.7, and all previous versions.” I suspect that is a little premature as we are on Beta Version 2.
  2. Chris Goodell
    on February 8, 2021
    Correct. Use the beta version for testing and training, but better to wait for the official release of 6.0 before using it for a project.
  3. Diana
    on February 15, 2021
    Hi Chris, I’m on the 5.0 version of HEC-RAS and I’m having trouble with my XS labels. I’m trying to create a geometry for the bathymetry but the XS labels are not in a consequential manner and thus are connecting XS that are not next to one another; creating channels where there shouldn’t be any. Any idea on why the river stations numbering are acting this way? I know the label should be the distance between the XS to the downstream of the river, but it seems my XS labels are not following this rule. Appreciate any direction you can nudge me to for a solution.
  4. Chris Goodell
    on March 4, 2021
    The labels are whatever you assign them and are not tied to the actual spacing between cross sections. Unless you created them geospatially with GeoRAS or RAS Mapper. Also, if the cross sections are georeferenced, but the coordinates are wrong, they could be placed in non-sequential order. Check the coordinates of the cross section cutlines and make sure they are correct.
  5. Lana Bayless
    on February 26, 2021
    Chris – I am running the Beta Version 2 to do a fairly simple analysis. I am fairly new to HecRas – so am not sure if this is a bug – or something with my model itself. Could you offer any insight on the following error message:
    Plan: ‘Plan 02’ (BPS-Existing2.p02)
    Simulation started at: 26Feb2021 10:49:35 AM
    Writing Geometry…
    E-171st_So: Mesh property tables are current.
    E-171_No: Mesh property tables are current.
    No-Military: Mesh property tables are current.
    W-171_NW: Mesh property tables are current.
    W-171_SW: Mesh property tables are current.
    W-171_West: Mesh property tables are current.
    Completed Writing Geometry
    Writing Event Conditions …
    Completed Writing Event Condition Data
    Steady Flow Simulation HEC-RAS 6.0 Beta
    Subroutine HDF_OPEN_LAT
    #000: ..\..\src\H5G.c line 285 in H5Gcreate2(): no name
    minor: Bad value
    Stored maps were not written because the simulation did not complete.
    Computations Summary
    Completing Geometry 1
    Completing Event Conditions <1
    Steady Flow Computations <1
    Complete Process 2
    Any help you can provide would be appreciated.
  6. Chris Goodell
    on March 4, 2021
    The messages about the mesh property tables implies you have some 2D areas. But there’s also a message saying “Steady Flow Simulation HEC-RAS 6.0 Beta”. That implies you are running a steady flow simulation.
    You have to run 2D areas using unsteady flow.
  7. Jimmy
    on March 10, 2021
    It seems the the stage and flow hydrograph function does not work under Beta 6. I also have problem with DSS times series plot when I specify, for example, a flow hydrograph for the upstream XS for unsteady flow. After I run the model in beta 2, but open it in v5.07, both of the above functions work.
  8. Chris Goodell
    on March 23, 2021
    Thanks for letting us know! Would be good to send that to HEC as a bug report.
  9. Jim
    on March 23, 2021
    HEC just released V6 Beta 3 and both of the issues have been fixed from my test run.
  10. Brandon C.
    on May 25, 2021
    Hey Chris,
    Thank you for the constant excellent content.
    We are working in RAS 6 Beta Update 3 currently with a full 2D model containing a single 2D area, using the rain-on-grid method and diffusion wave equation set. The 2D area has 40+ bridges and 120+ culverts.
    We are running into an issue where the model runs for a time with generally good results, but at some point it stops calculating any movement of water. Water surface elevation, flow, and structure hydrographs all “flatline”, so to speak. Further, the “computations” from this point on take about 2.5 times longer than model runs which do not have this error. A model which takes 4 hours to successfully run a 7-day storm event instead takes about 10 hours to finish calculating mostly unusable results. I have not read about anyone else having this issue, but we have 2 teams working on a handful of similar models of other watersheds, and we have all run into this “flatline” error at some point or another in Beta 2 and Beta 3. It seems to be related to 2D Area Connections, as runs without bridges and culverts (i.e. mesh only) do not flatline nor do runs fewer bridges and culverts.
    Do you know anything about this or have any suggestions?
    Thank again,
    Brandon C.
  11. Chris Goodell
    on May 27, 2021
    With 40+ bridges and a 4 to 10 hour run time, this model will be very difficult to troubleshoot. But it sounds like you have some instabilities. Try shortening up your model simulation time as much as possible to troubleshoot. Perhaps you can start it where the trouble begins. Then I would add one or two bridges at a time and see if you can pinpoint which bridge is causing the trouble. Unfortunately, this is going to take some work for you to figure it out.
11 + twenty =
