HEC-RAS Version 5.0.1 is now Available!
Written by Chris Goodell | April 22, 2016
A new “bug-fix” version of HEC-RAS has just been released (5.0.1).  A few computational bugs were identified since the release of 5.0, which were severe enough that HEC needed to fix them promptly.
You can download the latest version from the HEC web page:
http://www.hec.usace.army.mil/software/hec-ras/
The following is a list of bugs that were found in version 5.0 and fixed for version 5.0.1:
1. Unsteady Flow with Pumps: A pumping station that is connected “From” a storage area had a bug that could generate an “access violation” error.
2. Unsteady flow with rating curves at structures: The rating curves for: inline structure outlet rating curve, lateral structure outlet rating curve, and user defined gate rating curves (both inline and lateral) have been changed so that unsteady will no longer extrapolate past the top or bottom of the curve. A warning will be generated the first time this happens.
3. Unsteady flow with an SA/2D Hydraulic Conn between two 2D areas: There was a bug when a SA/2D connector has a 2D area on the upstream side. This bug would sometimes show up as an “access violation” error.
4. Steady Flow Analysis (Encroachments at Bridges): There was a bug when type 1 encroachments were specified immediately adjacent to a bridge opening. The encroachment was being set to the opening. The left encroachment was set to the left side of the bridge opening and the right encroachment was being set to the right edge of the opening.
5. Unsteady flow with 2D areas/Internal Hydraulic connector: For a hydraulic connector inside of a 2D area, the DSS output for headwater and tailwater had a bug. The reported values were “one cell” away from the intended values. For a connection that was entirely inside of a single cell, this resulted in a reported water surface of “0.0”. This was only a reporting issue.
6. 1D Velocity plotting in HEC-RAS Mapper for metric data sets: 1D HEC-RAS Mapper maximum velocity plot was wrong for SI data sets.
7. Unsteady flow Lateral Structure connected to a 2D flow area: For a lateral structure connected between a 1D river and a 2D area, the lateral structure was pulling the water out of the river at the wrong cross section location. The flow was being removed from the 1D river upstream of the location it should have been removing it from.
8. User Interface – Right Bank of Main channel: If you had a cross section with a vertical wall at the right bank of the main channel, the interface was displaying the main channel bank station at the bottom of the vertical wall. The computations were correct, this was just a visual problem in the interface.
  1. vladimir
    on April 24, 2016
    we can also have the new version and the previous one for parallel simulations
  2. Xavier Torrella
    on April 27, 2016
    I have installed the new version and created a terrain with a float (.flt) of a simple geometric channel with vertical walls.
    My operation semms to show no progress beyond the following;
    "Final Processing: Terrain.hdf
    Step 1 of 3: Creating Terrain.vrt…"
    (The operation is stuck here..)
    I want a reply. Thanks
  3. Anonymous
    on May 3, 2016
    Hi Chris,
    In prior version of HEC-RAS, the software wouldn't open unless the decimal symbol of the system was set as period.
    Now in version 5, it opens with error, but the bigger problem is that nothing warns the user about what is causing them.
    Hope they can make this improvements in future versions!
  4. Jai P
    on May 3, 2016
    Hi Chris,
    Does HEC-RAS 5.0 allow the actual channel (reach) to be modeled in 2D, or only the area alongside/downstream/upstream of the reach? If not, do you think this is a feature that might be added in the next version?
    Jai
  5. Chris Goodell
    on May 3, 2016
    Yes, you can model everything in 2D, if you'd like.
  6. Davis Murphy
    on May 4, 2016
    This comment has been removed by the author.
  7. Davis Murphy
    on May 4, 2016
    I am still experiencing floodway computation issues in the 5.0.1 version of HEC-RAS in 1D steady modeling. I have a couple culverts in a model that show erroneous velocity heads at the 4 section and the model does not compute any floodway profile information at the 3 section.
    Anyone else experiencing this issue?
  8. Davis Murphy
    on May 4, 2016
    I updated to the latest version due to the encroachment issue around bridges and have noticed another issue computing floodway profiles around culverts. My results are showing erroneously large EG elevations at the 4 section and no data is reported at all at the 3 section.
  9. Davis Murphy
    on May 6, 2016
    I submitted a bug report to HEC and received a reply acknowledging there is a bug with floodway encroachments in 5.0.1. They suggest using version 4.1 for floodways until the next update.
  10. Chris Goodell
    on May 6, 2016
    Thanks Davis for looking into this and sharing with us!
  11. Derek Etkin PE
    on May 10, 2016
    I just discovered that the culverts in internal SA/2D Area Connections cannot support reverse flow 🙁
    I am simulating a tidal marsh connected to the ocean by a couple culverted channels, which I'm representing with internal SA/2D Area Connections. The tidal prism moves out, but not back in!
  12. Derek Etkin PE
    on May 10, 2016
    I just discovered that culverts in internal SA/2D Area Connections inside 2D areas cannot support reverse flow; only flow from the HW side to the TW side.
    I am using a single 2D area to simulate the tidal prism of a saltwater marsh connected to the ocean by a couple culverted channels. When the tidal BC on the TW side of the culverts drop, the prism flows out through the culverts, but when the BC rises again the profile is held at the culverts with no flow coming into the marsh.
  13. Chris Goodell
    on May 11, 2016
    HEC has just tested this in version 5.0.1 and it does allow reverse flow. Are you sure you aren't using flap gates?
  14. Derek Etkin PE
    on May 12, 2016
    Thanks for the response! I have "No Flap Gates" selected, so I'll have to dig a little deeper I guess. At first I thought it might be a problem with the stationing/invert of the culvert in the SA/2D Area connection, but the culvert invert is equal to the HW/TW Cell Min Elev's that correspond to the stationing of the culvert opening
  15. Joe Kelly
    on June 14, 2016
  16. Joe Kelly
    on June 15, 2016
  17. Chris Goodell
    on June 15, 2016
  18. Joe Kelly
    on June 15, 2016
    I did draw in an object (storage area). Then typed in the boundaries and it worked. I then deleted the bogus storage area. Evidently a blank screen doesn't work.
  19. Joe Kelly
    on June 16, 2016
  20. Joe Kelly
    on June 27, 2016
    This comment has been removed by a blog administrator.
  21. Joe Kelly
    on July 6, 2016
    Found out from USACE-HEC that the error was due to where the documents are in the directory. Changed location and the program ran.
  22. Eric Toth
    on August 4, 2016
    Hi Chris,
    I am performing a 1D/2D sunny day dam break simulation with v5.0.1. The reservoir is modeled with a SA; downstream is modeled as 2D flow area. The dam (weir) and breach modeled with a SA/2D Area Conn. I received the following message(s) in the simulation starting at about 2 minutes after the end of the breach formation time (1 hr).
    In green text it said:
    1D/2D Flow error -31 LafDam
    The error lasted for about 23 minutes and the simulation didn't stop running.
    Any thoughts as to what may be causing the error?
    Thanks.
    Eric
  23. Anonymous
    on September 25, 2017
    Hi Chris, I have connected 2 storage areas with the SA/2D connector in HECRAS 5.01 to represent a dyke between two reservoirs. After running the unsteady flow model, the hydrograph and stage plot of the connector shows blank with the message " no data to plot". I have tried increasing flow in one of the reservoirs to ensure overflow, but the error still persists. What could i be missing?
  24. Chris Goodell
    on September 26, 2017
    First, I suggest upgrading to version 5.0.3. Second, make sure that you have selected "Storage Area Connection" under the Type menu item on the stage and flow hydrograph plot. If still there is no data to plot, that means the simulation did not complete (maybe from an instability).
  25. Anonymous
    on November 30, 2017
    Hey Chris, I just noticed something that might be helpfull to others. I was modeling dam breach as an internal structure in a single 2D area (modeled with the 2D area connection). I could not get the dam to actually breach when I used the option to initiate the breach at a certain headwater level. It turns out it matters which way you draw the 2D area connection, i drew mine from the right to left bank and therefore HEC-RAS thinks the downstream area is the headwater. I found this out by using the "plot flow and stage hydrograph" from the main window.
  26. Chris Goodell
    on December 1, 2017
    Nice! Thanks for sharing!
    -Chris
eighteen − 18 =
