International Settings
Written by Chris Goodell | June 10, 2014
To my international HEC-RAS user friends.  It’s time again to remind everyone that you need to have your Region and Language Windows settings set to English (United States), particularly if you are running unsteady HEC-RAS models.  If you live somewhere other than the USA, and you get an error message relating to the “time” data, or “date” inputs, it’s a good bet that you need to change your region and language settings.
  1. Jordi Oliveras Ferret
    on June 11, 2014
    Thank's Chris… I've always thought that setting any English format was enough… I've always set English (Australia), because it's the fisrt of the English format list, and HEC-RAS computed ok…
    But once I got an error message abou time, and now I know why!!!!
    Best regards.
  2. Anonymous
    on December 4, 2016
    Thank you very much!!!!! I solve this problem thanks to you sir!!
    Thank you!!!
  3. Unknown
    on January 3, 2018
    hi,
    After i change the format as seen above, the plan file does not read the date right and the date column is empty…
    What should i do?
    Thank..
  4. Eliav Beck
    on January 3, 2018
    hi there,
    After changing the format as seen above. the date column in the flow Hydrograph window dose not fill in automatically and i cant compute the simulation..
    What should i do?
    Thank!
  5. Chris Goodell
    on January 4, 2018
    Try re-entering the dates in the unsteady flow analysis window in this format: 04JAN2018
  6. Anonymous
    on March 2, 2019
    Thank you very much Chris for this reminder which seems so basic but which annoys me so much!!
4 × 4 =
