Quickly Edit Reach Lines in the Geometry Editor
Written by Chris Goodell | June 27, 2013
Editing the positioning of your geometry in HEC-RAS can sometimes be a pain, especially with large systems. This tip will show you how to quickly (and easily!) remove sections of a reach. If you import reach stream lines through ArcGIS, or a similar program, your schematic may look similar to the figure below. image In this example I want to remove a large section of the reach, and the method of clicking each node to would be very time tedious and consuming. Manual edits can be useful for editing small portions of a reach or storage area, but not for hundreds or thousands of points! Instead, navigate to Reach Invert Lines Table … under GIS Tools in the Geometry window. This will bring up a table of all the points in the reach, which are organized by XY coordinates. From here you can remove or edit a large portion of points. XY coordinates are shown in the bottom-right corner of the Geometry window when hovering the mouse around the area you are interested in. image
  1. Anonymous
    on June 7, 2016
    I just create a temporary reach connected to a point in which I want to break my true river. When junction is created, river divided into two section is made. Next you just have to delete both: your temporary river and unwanted section. It's a trick for lazy people. 😉
    Take care,
    Kinga
  2. Anonymous
    on February 7, 2017
5 − five =
