Re-Projecting HEC-RAS Model Geometry
Written by Chris Goodell | October 16, 2014
HEC-RAS 5.0 now provides a tool for quickly re-projecting model geometry within RAS. It is accessible from the main RAS interface under the Options menu…Convert Horizontal Coordinate Systems.
clip_image001
From this window, the user must select the Current Project Spatial Reference System and the Destination Project Spatial Reference System by loading the appropriate projection file (*.prj) for each. Do not confuse this file type with an HEC-RAS project file (also *.prj).  Once the projection files are loaded, click OK.
clip_image003
A warning window will appear alerting you that running this tool will automatically save the data to disk. If you do not wish to overwrite your existing RAS project files, click cancel, save the project as a new name, and convert the duplicate project. Otherwise, click OK.
clip_image005
  1. Fly on the Sky
    on March 18, 2016
    Hi Chris,
    Do you know if there is a way to determine a HEC-RAS model's projection/spatial reference system when we were not told?
    Thanks!!
    Derek Chang
  2. Chris Goodell
    on March 21, 2016
    Derek- Give this a read and see if it helps:http://hecrasmodel.blogspot.com/2015/05/the-projection-file.html
    Essentially it requires some trial and error work. Experience working with projections will speed up the process.
    Good luck-
  3. jc
    on November 8, 2016
    Hello, I get the following error when I convert project coordinates. Do you know of a way I can resolve this error? THanks
    Warning – An error occured in geometry data SRS conversion.
  4. Anonymous
    on August 17, 2017
    Hi JC, I got the same error, but it converted the projection anyway! You might see if it worked despite the error.
  5. Unknown
    on January 8, 2019
    when i do that it appear error in saving file alrady open how i solve this problem
fifteen − ten =
