The Projection File
Written by Chris Goodell | May 14, 2015
RAS Mapper is a window in HEC-RAS that allows you to preprocess 2D areas, map results, and manage background images.  In future versions of HEC-RAS, RAS Mapper will become more and more prevalent in our HEC-RAS modeling experience.  As I understand it, eventually RAS Mapper and the geometry editor window may merge to form the front-end interface for HEC-RAS, replacing the iconic “Main RAS Window”.
But that’s speculation.  What is not speculation is that if you want to use HEC-RAS 5.0 for anything more than a very basic model, there is really no getting around using RAS Mapper, and by extension…The Projection File!  The projection file defines a specific geographic coordinate system and projection and is somewhat of a new thing for us HEC-RAS modelers (it has actually been a part of RAS Mapper since it’s inception, but now with 2D modeling and web-imagery in Version 5.0, RAS Mapper is becoming an integral part of HEC-RAS modeling). The projection file requires us to know something about geospatial mapping (i.e. GIS), which we really haven’t had to know too much of before as RAS users.  But if you wish to use RAS Mapper, and you will, you need to understand what the projection file is and how to get one.  Without it, RAS Mapper is pretty much useless.  Adding a projection file to our RAS project establishes the project’s geospatial reference.  Projection files have the extension *.prj.  Be careful not to confuse this with the HEC-RAS project file, also with an extension *.prj.  They both reside in your HEC-RAS project directory, but only a properly formatted projection file will work in RAS Mapper for setting your projection.
The projection file is really just a simple text file with keywords in a specific format.  In fact, it is a single string written in “Well-Known Text” format, or WKT.  It’s simple, easy to read and was created by the Open GIS Consortium.  Here’s what a projection file looks like on the inside.  Notice that there are some keywords, identified by all CAPS, followed by some data related to the key-word, contained in brackets [  ].  I’ve color-coded it to make it easier to see what goes with what.  The purple color denotes the highest order in the hierarchy, followed by blue, then green, then red.  In other words, a red keyword is a “child” to a green keyword, green is a child to blue, and blue is a child to purple.
Each keyword and the bracketed data that follows is called a “clause”.  The first and primary clause, PROJCS, stands for Projected Coordinate System.  The projected coordinate system is made up of the following sub-clauses:
1.  Geographic Coordinate System (GEOGCS), which is based on degrees latitude and longitude and contains the horizontal reference datum (DATUM), and the reference meridian for longitude measurements (PRIMEM).  DATUM also contains a description of the shape of the earth (SPHEROID), which in the example above is the Clarke Ellipsoid of 1866.  Units (UNIT) are inferred here only for the GEOGCS, in this case degrees.
2.   Projection (PROJECTION), which is the projection from geographic coordinates (lat/long) to projected coordinates.  This is essentially how the three-dimensional spheroid (Earth) is projected to a two-dimensional viewing medium.  In the example above, Transverse Mercator is selected, which uses the Universal Transverse Mercator (UTM) coordinate system.
Cylindrical projection – transverse aspect © USGS
3.  Various projection parameter values (PARAMETER).  The parameter is labeled in quotations, followed by its value.
4.  Units for the projected coordinate system (UNIT).  Here meters are used as the linear unit with a conversion factor of “1”.  The conversion factor converts the described units into meters.  If “FOOT_US” is used, then the conversion factor would be 0.30480060960121924.
There may be some additional clauses in your projection file, but the ones listed above seem to be typical.  All of the keywords used in WKT format with descriptions can be found at GeoAPI here.
You can write your own projection files and GeospatialPython.com presents a method (there are other examples out there, just Google it).  However, it is much easier and much more practical to find an already-compiled projection file and use that.  If you have a georeferenced HEC-RAS project already, every shapefile used to create your geometry components (stream centerline, xscutlines, flowlines, etc.) comes with a projection file.  Just find where it is stored on your computer and use that.
If you don’t have the GIS files that were used to create your georeferenced HEC-RAS project, you can find projection files in at least three different places:  ArcGIS 10.0 or earlier, spatialreference.org, and the EPSG Projection Database.  If you know of others, please comment below!
When using any of these sources, make sure you pick the correct projection file.  You’ll know if it is the right one by bringing in web imagery to RAS Mapper and checking to make sure that everything lines up spatially correct.  ArcGIS (Versions prior to 10.1) includes a Coordinate Systems folder that contains more than 5,000 geographic, projected, and vertical coordinate systems.  Unfortunately, newer versions of ArcGIS do not come with that folder.  If you have ArcGIS 10.1 or newer or don’t have ArcGIS at all, you can access a large database of spatial reference systems at http://spatialreference.org/
If you go to spatialreference.org, make sure you only select from the EPSG, IAU2000, or spatialreference.org references.  The ESRI references only contain the GEOGCS clause in the projection file and not the complete PROJCS clause.  They will not work in RAS Mapper.   Once you’ve found the reference you want, click on it, then select “.PRJ File” from the list of available formats.  A projection file will then be downloaded to your computer and you are ready to use it in RAS Mapper.  There is a convenient Search box that allows you to search on key words for your reference.  For example, if your project is in Hawaii and you know your horizontal datum is NAD83, you can enter the keywords:  Hawaii NAD83, click the Search button and you’ll see the following list of spatial references:
Also available on line is the EPSG Projection Database, hosted on GoogleCode by geospatialpython.org.  Here you’ll find a text file of a multitude of projection files in the correct WKT format that can easily be copied and pasted into your own projection file.
Once you’ve selected a projection file and assigned it to RAS Mapper, double-check that it is correct by adding web imagery.  If everything lines up, you are good to go.  The figure below shows the Muncie dataset in RAS Mapper, with an incorrect projection file assigned.
Obviously our streamlines and cross sections in this example are not correctly aligned in Muncie Indiana where they belong.  The incorrect projection file has landed us in the middle of Alberta, Canada!
Reassigning the correct projection file gets the model back to its correct spatial reference.
Does anyone know of any other sources of projection files that we can use in HEC-RAS?  If so, please comment below.
  1. Anonymous
    on May 14, 2015
    I saw your post on projections on your blog and thought it might be good to mention that you can convert the coordinate system of the model in HEC-RAS now.
  2. Chris Goodell
    on May 14, 2015
    Thanks. Good point.
  3. Cam Ackerman
    on May 15, 2015
    HEC-RAS supports esri's WKT format of the PRJ. Using other WKT formats is YMMV.
  4. Cam Ackerman
    on May 15, 2015
    HEC-RAS currently supports esri's WKT format. Other WKT formats are YMMV.
  5. Chris Goodell
    on May 15, 2015
    Thanks for the head's up. I believe all of the prj files on spatialreference.org follow the format used by HEC-RAS (at least the ones I've checked), except (ironically) the 447 ESRI references. They only have the GEOGCS clause, none of the others.
  6. Anonymous
    on May 19, 2015
    Hi
    Can I load own link WMS in the RasMapper?
    Because, my model is created in the S-JTSK / Krovak East North and bacgkround/WMS (ortophoto,satellite image) in the WGS-84. When I load a bacgkround, so my model is displaced out- this error is predictable.
    Best Regards!
    Robert
  7. Chris Goodell
    on May 19, 2015
    The projection that your model was created in and the projection you load in RAS Mapper must be the same.
  8. Robert S
    on May 21, 2015
    Chris confirmed my idea:
    When you work the other coordinate projections as WGS84, so you can´t use the WMS imagery servers (RasMapper- Tools). Nowday, RasMapper doesn´t support to join the other WMS.
    You have to solve a background using static image (georeferenced image)
    I hope, that I write it well, Chris!
    Best regards
    Robert
  9. Chris Goodell
    on May 22, 2015
    Robert. I think I understand your question better (with the help of Cameron at HEC). If you go to the HEC-RAS project directory, you will see a folder called GDAL. In there, you'll see a folder called Web Map Services. There you will see an xml file for every web imagery service available in HEC-RAS. If you would like to add more web imagery services, you can create your own xml and put it in this directory. It should then show up in the Web Imagery Window in HEC-RAS. If you are able to do this with your own web imagery, please forward the xml to me so we can share with others.
  10. Mike Chilson
    on May 28, 2015
    With ArcGIS 10.1+ simply add a projection to your favorite list and it will create and place a projection file at:
    C:Users"UserName"AppDataRoamingESRIDesktop10.2ArcMapCoordinate Systems
  11. Gerrit K.
    on June 3, 2015
    I'm very sorry for any cryptic parts of this message, but after some hours of investigating why the Hungarian EOV (Unified National Projection) is not projected correctly in RAS Mapper, I'd discovered that all information to do this correctly is available in the GDAL library that RAS Mapper uses.
    The erroneous projection might originally be caused by an error in a parameter value in the info source, but that has been long corrected and the correction is part of the GDAL library file 'datum_shift.csv'.
    There are actually 5 (!) datum shift parameterizations listed in this file ("SEQ_KEY" 350 to "SEQ_KEY" 354) and any of these would be much more accurately shift from HD72 to WGS 84 then the current implementation.
    So, Is the GDAL library only partly implemented? Or is there a bug that prevents RAS Mapper from applying the preferred datum shift defined in the GDAL library file 'datum_shift.csv'?
  12. Chris Goodell
    on June 3, 2015
    Gerrit- thanks for the information. I'm not sure what the issue could be. I'll point some others to your question to see if we can get a good response.
  13. Mike
    on March 15, 2017
    Hi Chris, thanks for this post. I'm having a problem with my geometry being offset from the WMS river/terrain (see link below). I've found a workaround by manually editing the .prj file, but will this affect the projection of the 2D model e.g. flood maps?
    http://hec-ras-help.1091112.n5.nabble.com/Problem-with-misaligned-spatial-projection-prj-British-National-Grid-tt3753.html
  14. Chris Goodell
    on March 15, 2017
    Hi Mike. That's a good question. I'm not sure how it will work. My gut instinct says it should work fine, but I think this is just one of those things you have to try out to know for sure. Let me know how it goes.
  15. Unknown
    on March 29, 2017
    Is the projection file only significant for RAS-Mapper, or geometry as well? I inherited a RAS model that is supposed to be working, they even sent over final run results. I am not able to run it because of a geometry error – it seems some river reaches are not lined up correctly to their associated cross sections. Also some weirs fall below the terrain elevation. I believe these issues might be because of a lack of projection file.
  16. Chris Goodell
    on March 29, 2017
    It sounds like errors in the geometry setup. Should have nothing to do with the projection.
  17. Colin Holdgrafer
    on October 5, 2017
    I have a project where RAS Mapper was displaying the map just fine using a UTM Zone 15 NAD83 (meters) projection file, but when I converted the project from meters to feet using Options->Convert Project Units, the map no longer worked. How do I change my projection file for the new project so it'll display the project in the right place? Or would it make more sense download a new projection file based on the unit conversion? And if so what would that new horizontal datum be?
  18. Chris Goodell
    on October 6, 2017
    You'll have to get a new projection file (or create your own) that has the correct unit system.
  19. Colin Holdgrafer
    on November 3, 2017
    The thing is that the projection is still UTM Zone 15 NAD83 (meters), but it's just been converted to feet now.
    This is how the coordinates changed after the unit conversion at a specific point where a cross section intersects with the river reach:
    (Originally) Meters: 451305.5383, 4625115.6106
    (After conversion) Feet: 1480661.2147, 15174263.8183
    Here's the shape projection file I was using before I did the conversion:
    PROJCS["NAD_1983_UTM_Zone_15N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-93],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
    How should this be modified to make it so my project doesn't end up in the middle of the Arctic Ocean after the unit conversion? I've tried modifying the UNIT["Meter",1]] to say UNIT["Feet",3.28084]] but that doesn't seem to fix the problem.
  20. Ben Snyder
    on May 9, 2018
    I've been trying to resolve a mysterious horizontal datum shift that RAS does for quite some time. I export a surface from Civil 3D using CA State Plane Zone 1, US Feet, EPSG 2225. For my latest work-around test, I made a projection file for RAS that has the exact same projection data as the Civil 3D tif. It says "Same As Project" when I make a new terrain. Then when I open the geometry editor and look at the coordinates of a landmark, it's off by about 12 feet in the easting direction and a few in the northing. The shift is NOT there when i bring the tif into GIS, so it doesn't seem that it's a problem with Civil 3D export. I'm stumped! Any ideas? It's problematic because all the RAS results rasters are then shifted and don't line up.
  21. Ben Snyder
    on May 9, 2018
    Actually, that worked! RAS users who work with Civil 3D may need to ensure that the SRS is "Same As Project" in order to avoid having a mystery shift occur. But as long as they're exactly the same, they should be good to go.
  22. Anonymous
    on July 22, 2018
    Hello, I need your help. I can not make the prj file work from: "http://spatialreference.org/". I need for "EPSG: 22174: POSGAR 98 / Argentina 4"
    I can not find the error. Thank you very much.
    PROJCS["Gauss-Kruger",GEOGCS["Campo Inchauspe",DATUM["D_Campo_Inchauspe",SPHEROID["International_1924",6378388,297.000745017694]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Gauss-Kruger"],PARAMETER["False_Easting",4500000],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",-63],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_of_Origin",-90],UNIT["Meter",1]]
  23. Anonymous
    on February 5, 2019
    HEC-RAS project is setup as follows:
    • Units: US customary
    • LiDAR dataset
    o State plane projection
    o Horizontal units = international feet
    • Projection used in RAS Mapper
    o Horizontal units = meters
    Aerial imagery lines up correctly. But, when the measure tool is used in RAS Mapper, it gives distances in feet but the measurement indicates it should be meters. For example, a distance that measures 10 feet with the measure tool is actually 10/0.30458 = 32.8 feet. Will this model produce correct results or is the landscape through which the flow is routed basically shrunken by a factor of 3.28 (1/0.3048)?
  24. Chris Goodell
    on February 5, 2019
    I think that’s just a bug and you’re okay. But make sure to double check.
  25. West
    on June 11, 2020
    Hi Chris,
    You talked about unit in this post.
    So I have the similar question about unit with HECRAS.
    Here is my case. We work with US partners in this watershed (Souris River watershed). They are responsible for developing and calibrating HECRAS, they use English unit, i.e., feet in all data and calculation. Then we use this model in Canada; however, we use SI in terms of flow, elevation, distance etc.
    Can I use this model by simply convert unit to SI, or this is not a correct way to use this model. The correct way to use this model in Canada is to prepare input flow as English unit, run the model, and read results in whatever units we select. I think this thought makes sense, and confirmed with experts in CivilGEO. But Chris I still like to know your thought.
    West
  26. Chris Goodell
    on June 12, 2020
    Hi West. In theory, you can just convert your model to a different unit system by using the Convert Project Units option from the main RAS window. However, I would be very cautious when doing this, because RAS has been known to have some errors in this conversion utility. At the very least, you need to check everything after the conversion to verify that it was done correctly. And don’t forget to update your projection file if necessary. RAS won’t automatically do this.
    Better to start the project in your preferred units, if possible.
  27. Breanna
    on April 7, 2022
    Hello, I am having an issues with HEC-RAS, specifically RAS-Mapper, that seem to be some sort of bug associated with my account. When I try to put in a projection an error occurs. I go project > set projection and when the box comes up that allows you to browse to a file and apply, the box seems to have a bug in it. It seems as if the bottom part where there should be the ‘okay’, ‘cancel’, and ‘apply’ buttons has just been cut off. I have tried resizing the box but nothing seems to work. I have also tried opening a different HEC-RAS window in a different, remote server but have the same issue. However, when my colleague uses the same remote server but a different account it works for her. My colleague has been using the same projection I am using (I sent it to her) and it works for her, so it is not an issue of the projection file.
    In addition to this bug, an error has been popping up randomly and frequently. It states ‘Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately. Object reference not set to an instance of an object.’
  28. Chris Goodell
    on April 11, 2022
    Try using a different screen resolution. This will typically fix this issue.
  29. Rupayan Saha
    on January 31, 2024
    I have a gridded precipitation .dss file that has spatial references: WGS 72 whereas my RAS Mapper projection is set in a State Plane coordinates. If I apply this precipitation .dss file in my model, will it automatically transform the dss file into State Plane coordinate?
  30. Chris Goodell
    on March 6, 2024
    It should. Try!
14 + 13 =
