If you have built enough HEC-RAS models, you’ve probably discovered that having data in different vertical datums is a bit of a pain. RAS lets you adjust the vertical datum of individual cross sections (under “Geometric Data”, “Cross Section”, “Options”, “Adjust Elevations”) or portions of the model (“Geometric Data”, “Tools”, “Datum Adjustment”). However, I have […]
Read More
Read More
