Lateral Structure on River Bends
Lateral structures can be used in HEC-RAS for transferring flow from a river/reach to another river/reach, 2D area or storage area. This allows the user to physically represent a variety of geometric features. In this example, lateral structures were used to capture flow overtopping high ground on the spine of a sharp river bend in […]
Read More
1D/2D Offline Connection Issues
Written by Chris Goodell | Kleinschmidt Associates Copyright © The RAS Solution.  All rights reserved.  I’ve mentioned this before, but I am thoroughly impressed with the robustness of the finite volume solution scheme used in 2D areas in HEC-RAS.  As long as your Courant Numbers are in a good spot, you rarely get errors and instabilities in […]
Read More
Weir Equations in HEC-RAS
HEC-RAS has the ability to simulate flow at hydraulic controls in a variety of ways. Bridges, culverts, inline structures, lateral structures, and SA/2D area connections can all act as hydraulic controls.  Effectively, they break up the conservation equations used between cross sections in a 1D reach and/or cells in a 2D area with empirically derived […]
Read More
Read More
Read More
I am working on a dam breach project where I’m trying to simplify a complicated model with dozens of tributaries and storage areas. In the process, I’m converting a few tributaries into storage areas (which are surrounded by other storage areas). For example, I want to convert the reach below (from 5.43 to 0.55) to […]
Read More
Advanced Rules for Unsteady Flow
This is a great presentation put together by Mr. Steven Piper of the Hydrologic Engineering Center that discusses in detail the use of “Rules” at inline structures.  Dr. Michael Gee forwarded this presentation to me after seeing some discussion on the forum about the use of Rules for inline structures.  Thanks for the suggestion Dr. […]
Read More
Read More
Read More
