Time Series Outflows for Dams
Want to simulate a time series of outflows for a dam?  It’s easy.  In Version 5.0.3 there’s a new feature called Outlet T.S. (Outlet Time Series) in the inline structure editor.   Click the Outlet TS button and give your new time series a name.  You might name it “Powerhouse” or “Fish Bypass” or something […]
Read More
Read More
Sediment Transport Quasi Unsteady Flow Editor Flow Series Error
“Flow or Temp time series date is not sufficient to run requested time window.”  This one has been around for a while, but it just showed up again on the Facebook HEC-RAS User’s Group, so I thought I’d show the fix(es) here.  This applies to the new beta version of 5.0, as well as previous […]
Read More
