Q & A: Flow Attenuation
Question: When running an unsteady flow model with a single inflow hydrograph, why does my discharge decrease in the downstream direction for a given output profile? Answer: This is called flow attenuation.  You see this to varying degrees in all unsteady flow models and it is a real phenomenon.  The shallower the reach, or the […]
Read More
Modeling Junctions for Unsteady Flow Analysis
In the current version of HEC-RAS (v 4.1.0) there are two methods of modeling the hydraulics at a junction for unsteady flow. By default RAS selects the Force Equal WS Elevations (Forced) method, which forces the upstream bounding cross-sections’ water surface equal to the downstream water surface. This method may be adequate for some situations […]
Read More
By using the Mixed Flow Regime option for Unsteady Flow Analysis, RAS can better handle transitions from subcritical to supercritical flow. This option should be utilized only after determining that a mixed flow situation exists, which requires judgment from the modeler. One application where this could be particularly useful is dam breach modeling, or any […]
Read More
Contraction and Expansion Losses for Unsteady Flow
Written by Chris Goodell, P.E., D. WRE | WEST ConsultantsCopyright © RASModel.com. 2010. All rights reserved.Since unsteady flow was introduced in HEC-RAS years ago, the contraction and expansion loss coefficients were not used, because losses due to contraction and expansion were automatically approximated in the conservation of momentum equation. Since steady flow RAS does not […]
Read More
