Lateral Structure on River Bends
Lateral structures can be used in HEC-RAS for transferring flow from a river/reach to another river/reach, 2D area or storage area. This allows the user to physically represent a variety of geometric features. In this example, lateral structures were used to capture flow overtopping high ground on the spine of a sharp river bend in […]
Read More
Weir Equations in HEC-RAS
HEC-RAS has the ability to simulate flow at hydraulic controls in a variety of ways. Bridges, culverts, inline structures, lateral structures, and SA/2D area connections can all act as hydraulic controls.  Effectively, they break up the conservation equations used between cross sections in a 1D reach and/or cells in a 2D area with empirically derived […]
Read More
Read More
Flow spike after peak of dam breach floodwave.
Just ran into an interesting phenomenon.  I was running a dam breach model with fairly typical breach parameters and piping failure mode.  After the peak of the breach hydrograph, there appeared a mysterious “spike” as shown in the figure below. This happens to be right at the same time the flow through the developing breach […]
Read More
